Brookes Web Site
Date:  8-18-2010
Number of Hours:  5.25
Manual Reference:  11.1
Brief Description:  Determine Hub lenght for Aero Composite prop
Used a spinner jig to determine where the cowl would be cut off to match the Aerocomposite spinner. I determined that the distance from the aft side of prop flange to cowl opening would be 2 7/16 inches. I relayed this number (2.43 in) to Aerocomposits so that they could machine the custom made hub to the proper length. I cut off the cowling flanges and opened the wing hole. I decided that final fitting of the cowlings should best be done after the prop is installed.
Lower cowling in place with spinner jig
Lower cowling
Lower cowling
wing cutout
wing cutout
Copyright © 2001-2017 Matronics. All Rights Reserved.
