Brookes Web Site
Date:  1-5-2011
Number of Hours:  7.00
Tapped holes for screws mounting com panel to bracket. Installed com panel in keel. Looks good. Trimmed hole in carbon fiber keel cover. Used foam, hot glue, and release tape to fabricate a 4 bid top and bottom for the com panel enclosure.
Mounted fuel pump temporarily with 1 2.5 in adel clamp. Measured for hose from electric pump to mechanical pump. Ordered 17.5 in preimpregnated, ss, teflon hose.
Removed preoiler. Tapped a 1/8 NPT thread into side of "out" elbow. Installed pressure switch into threaded hole. Pressure switch is supposed to be preset at 55 PSI. Will lower to about 30 when I get the pump working. This pressure switch was put in to turn the pump off when pressure is reached in order to avoid overpressurizing pump when check valve is closed.
Top and bottom of cutout ready for glassing
Note pressure switch tapped into elbow
It fits!
It fits!
Copyright © 2001-2017 Matronics. All Rights Reserved.
