Installed 2 adel clamps each on fuel pump and filter.
Determined and marked positions for seat belt hard points.
Took inside and outside protective brown paper off windscreen. Trimmed up fiber glass around inside of windscreen to try to eliminate the use of moulding when interior goes in.
Opened up groove made earlier for the forward edge of the glareshield. Expanded groove by inserting foam then heated to try to change shape.
