Brookes Web Site
Date:  4-24-2008
Number of Hours:  6.00
Manual Reference:  6.7.2
Brief Description:  Main (Center) Spar Installatin
Dry fit main spar several times. Only slight adjustment with shims made on pilots side. Shimmed the pilot side spar up with 3 tongue depressors forward by 2 tongue depressors. Set spar into position with help of Ginger and John Cyr.
Leaving overcentering gear mechanism in place was not a real problem, but should have taken it out to make spar placement a lot easier.
Pilot side (note shims)
Wedged into positon pax side
Spar against firewall
Copyright © 2001-2017 Matronics. All Rights Reserved.
