Brief Description: Added dyed fiberclass strips to the canopy skin jo
Sanded the initial filler material flat at the canopy/skin joint. Started the build up of the fiberglass/epoxy transition from the forward skin to the canopy. Dyed the first layer of epoxy with black pigment. sandwiched the ply between plastic sheets and cut to size before appying to the joint. My friend Terry helped to get this done and it was a good thing as the epoxy set up much faster than I expected even though I used the slow hardener.
