Brief Description: Fully finished SD-00001 service bulletin
Cut off the old connector on the wiring that comes down the tail cone. For some reason they used two white wires for power wires so I did a continuity check and identified one wire, and took a magic marker to it. This will be the gray/black wire and installed it in pin 5. Also marked it at the foreward location.
