I tested the range of travel with the motor and everything is fine. Then mounted the motor unit to the servo tray, ran the wires through the snap bushing, attached female DSub pins and stuck them in the connector. I screwed up a couple of pins but I had about 50 left over from the RV-7A project years ago, so no problem.
I reattached all of the components to the servo assembly and called it a day.
The only thing I still need to do is cut off the old connector on the wire at the rear fuselage and add new DSUB pins and connector
