I checked with Eric at Van's who said the fuel pump comes with the powerplant kit so he advised running the fuel lines based on the dimensions in the section and then move on to rudders and brakes so that's what I'm doing.
I did some scrap work to remember how to use the pipe bender and made the line that runs from the fuel tank bank to the connectors at the fuel valve (Van's sent me the wrong valve so Eric is sending a new one and I sent this one back).
I can't imagine what this will be like when I put the tailcone on because it's really hard to get to the connector at the fuel tank. Not sure how I'm going to torque it up.
I also made one line that runs from the firewall bulkhead fitting back to the first area under the floorboard and that went well to.
