Riveted the step brackets to the outboard baggage ribs. Started placing the factory head of the rivets on the bracket, but as it is the thicker material, I was getting gaps between the bracket and the rib. So I drilled out the first rivet and went with putting the factory head on the rib. Doesn't look as pretty, but it eliminated the gaps.
