Brief Description: Installed wiring conduit in right wing
Installed Van's wiring conduit in the right wing. The conduit was in a 50 foot roll and I started by feeding in through the outboard wing rib. I fed in one rib bay's worth at a time and then moved the slack on down the wing. I found the easiest way to feed it through the ribs was to grasp the conduit on both sides of the rib and pull in opposite directions putting the conduit into tension and thereby reducing its diameter. Then, while keeping the tension on, I'd shift the conduit to the left through the rib a few inches, reposition my hands and do it all over again until I used up the slack. In less than 15-20 minutes (I didn't time it) I had the conduit installed and then used a box cutter to cut the conduit from the roll.
