Everyones down at the in-laws for Spring break. So with an empty garage I took the opportunity to cut out the leading edge cradle ends and flap cradle ends that are made from the top of the shipping crate. The LE ends come traced out on the top of the crate so all i had to do was cut them out. After cutting the 2 out, I decided to go ahead and cut out 2 more by using one of the cut ones as a template. I then cut out the flap cradle ends using the scrap produced from making the LE cradles.
I finished up by marking a center line down the LE J-stiffeners (image 1). This will alow me to match drill it to the LE later.
