Brief Description: Aileron hinge brackets & doublers
Trimmed and deburred the aileron hinge brackets. Clecoed and match drilled the right rear spar doublers. Transferred the push rod hole from the spar to the doubler. The shape is not the same that's in the plans, and going to be somewhat more difficult to cut out. As you can seen in photo 3, it's sort of an upside down pear shape whereas the hole in he plans is dipicted as a rectangle with rounded corners. Oh well...
