Brief Description: Riveted hinges and doubler to spar.
Riveted the elevator hinges and spar doubler to the spar, riveted the hinge bracket and bearing together and then bolted it to the spar. I don't have any torque seal so I need to place an order before I close the HS up. Started to fab the spar attach brackets and pretty much botched the whole thing. First I cut too close tot he lines so the shape of the brackets was OK but I wasn't pleased. However, I decided to live with it until I ruined the second bracket by mis-measuring the location of one of the 3/16 holes. Measure twice cut one --shheesh. OK so I'll shoot an order to Van's first thing in the AM.
Went ahead an movred on to fab'ing the stringers. Pretty much just pulled them out and got the plastic off.
