TODD'S WEB SITE
Date:  11-5-2006
Number of Hours:  3.00
Manual Reference:  Sec 7 - Rudder
Brief Description:  Installed Cnter-bal rib, rolling leading edge
Rivet in the counter balance rib and riveted the skin to the spar. No big issues here, except I bucked more rivets that I needed too. It gave me some good practice, but I scratched the spar up in the process. So when I was done I broke out the primer and a small paint brush and did some batch touch-up work on the rudder and the VS since I had the paint open. Note: the AFS primer is not not very tough and can easily be scratched off.
I began the process of rolliong the leading edge and discovered I didn't have the right diameter pipe anywhere in the house. I went ahead anyway and I'm not pleased what so ever. A trip to Home Depot is in the offing. Also, trying to put a bend in the edge of the skin is a real problem. I totalty dorked that up causing more harm then good. If there's any place I'm really weak technique wise, this is it. I've got to figure that damn tool out before I really do some damage.
Riveting skin to spar
More of the same
More of the same
Starting to roll leading edge
