Brief Description: Trailing edge wedge CSK - rudder ready for primer
Only did one step tonight but it took some time to setup. The job tonight was CSK the AEX wedge. Researched the task online a found a couple of different ways to do it. Based upon my previous experience with small aprts (the striker plates), I decided to go the drill press route for mounting the microstop to keep it perpendicular to the work. This methoud requires you to build a jig to hold the surface to be CSK's horizontal. Problem is the AEX wedge is just that a wedge so a jig is in order to offset the wedge so that it lays horizontal. I made made mine with scrap wood and the only scrap pieace od VA140 I had (what was left form triming the trailing edge to length). Glued to all togther and it worked like champ. The rudder is now ready for priming.
