TODD'S WEB SITE
Date:  1-26-2010
Manual Reference:  Sec 14 - Wing Ribs
Brief Description:  Matched drilled left wing ribs and spar
Trimmed 19/32 off the forward tabs of a 1011-R rib so they’d clear fuel tank nutplates at this rib’s attach point. After fitting the rib, 19/32 wasn’t enough and so I had to go back and trim off a little more in order to relieve the interference. Also cut off the rear flange of the 1012 outboard end rib. I then clecoed all the left wing ribs to the spar and matched drilled all of the bolt and rivet holes attach holes. Finished by taking everything apart for deburring.
Trimmed rib
Trimmed rib
Match drilling the ribs
Match drilling complete
