Brief Description: Profile sanding cowling transitions. Found a dip.
Sanded back the last fill.
Have noted for a while now that there is an unsightly dip in the top profile between the two parts of the turtleback. Looking at it in particular I can see it is only the matter of 1/8" to bring it into profile, I cut up some 1.5mm plastic window packers, tape them together and jam them into the gap, then slather FILL aft of this line. This leaves some obvious low spots, but I can't address them without peeling up the FILL, so this will require another round...
Remainder of fill into obvious low spots.
Sanding transitions. Note the gap in the profile at the turtleback join...
