Brief Description: Final stages bottom profile sanding & more rash!
Finished sanding all areas starboard wing bottom and fuselage aft bottom 320g dry and wet as needed.
Refited gascolator drilling guide in the conventional sense and drilled 3/32". Removed guide and opened up to 1/8" and properly countersunk the holes. All looks lovely now.
Store starboard wing, and manage to inflict hangar rash on the port!!! The tap test indicates there is a void, and there are visible damage to the fibres. F*&k!
This now looks acceptable
Autofocus not working here, but it looks much better.
