Brief Description: Profile sanding rudders. More wing bottom
Sanded port rudder inner surface and starboard rudder outer surface.
Discovered the Kruger flap I had built in on the starboard did not match the port very well, and I had damaged it. so sanded it off and prepared a replacement the same as the other. Prep sanded and layed up 3 x BID over the same form I used for the other.
Had a hard look at the wing, and whilst it looks fine, and a long metal ruler seems to have a nice profile throughout, when I run my hand chordwise I can feel a hump over the trailing edge of the spar outboard of the wing attach points. Applied some more FILL screed with a 12 inch steel ruler, and it took suprisingly little fill to hide my problem.
