Trimmed a bit more & checked hinge height. Was hornswaggled to discover they are still low. Measure carefully, and the outer & inner hinges needs 2 x BID, the mid 1 x BID over about 2/3 outboard.
Just for fun drilled and reamed the Wing and hinge holes to 3/16", marked clickbond head space and counterbored one as a trial with Dremel router.
Sanded up the hinge pads, and applied the schedule above.
Gazing dyspeptically at the cleco'd hinges through comical glasses repaired with Plastimorph
Gazing dyspeptically at the aileron through comical glasses repaired with Plastimorph
