Set the incidence, level and alignment. Mark the sides and F-22. Remove the Canard, trim and sand. Put the Canard back on, and repeat.
Finally happy with the Al shims in place.
Marked front tab location and removed canard.
Layed up a pad of 5 x BID, tapering to 1 at the top. Wet out the glass on peel ply on the bench and stuck them on. Lekky scissors are not working well, I think I've buggered them by forgetting to clean them.
Taped the tabs and clamped on the Canard, checking incidence, level and alignment.
Getting the incidence right
Laying up the pads
Clamped in place, tried using leftover resin to rough fill the Canard. Beastly stuff!
