Brief Description: Additional nose weight stations and other stuff
Started off making a thingie to have a bash at balancing the propeller. Seems to work, and indicates the prop balances within 2.2g at the tip, (one third of a sheet of A4 paper).
Made another nose weight from a 440ml Guiness can with a ringbolt suspended in recycled lead.
Trimmed exposed canopy bolt heads. The starboard longeron mount is a bit skew-whiff, but will work fine.
Hot glued and taped some coreflute forms around the new nose weight stations to ease taping, and whacked in some pour foam.
