Patched a couple of holes I punched through the nose bowl with 2 x BID patches on the inside, backed with duct tape on the outside.
1 x BID over Ballast Hatch window flange and weighted with foam.
Put nose bowl back on fus for cure with 4 x cleco. The nose bowl will go back on the fus for every cure cycle from now on, to avoid the warping that happened last time.
