Make a dam around the wing using plastic window packers and a couple of bits of coreflute and start to FILL the port wing. RUN OUT OF WESTS. I thought I had another bottle but it was empty. ON BOXING DAY. F&%K. Usual supplier is closed until the 5th of January...
Along the way evolve the plan of working aft from the spar,then doing forward from the spar, then patch the middle after at least partial cure. Look forward to trying it.
Had enough to at least finish the join to the strake, after scraping some FILL off the wing tip, so I can remove the hot glue blocks holding up the fence and fill the strake when I get supplies.
