Home of the Spodplane
Date: 11-21-2023
Number of Hours: 7.00
Manual Reference: 25-01
Brief Description: Profile sanding/FILL stbd wing/strake top and wing
God this is boring.
Ongoing work over the last week, profile sanding 40g, then patching low spots and egregious pinhole areas, then profile sanding again, or at least feathering the edges when I got it right. Tried to do detail work with 80g, but the results looked a bit shiny, so went back to 40g. Running low on 40g, so snuck in a run to Bunnings Aerospace...
I had the method initially of sanding the area over the spar cap flat, then working the curves toward it, but somehow managed to make flat areas either side of the spar cap. Hmmmmm.
Nice blurry photo disguising that I've got micro on the laundry footstool...
Sandy, sandy
