Brief Description: FILL starboard wing/strake top and winglet
Over the last couple of days, removed the hot glue blocks on the dam, and cut the coreflute down to one layer along the parting line. Removed the window and cap forms.
Applied FILL to remainder of prepared areas. Managed thickness by working the FILL well into the surface, then smoothing it to a reasonable even layer with a 12" steel ruler or the broad edge of my scraper. If it leaves a gap just leave it and refill tomorrow.
Have discovered that any blobs that land on the floor just leave them there, they will have debris from the floor...
