Brief Description: Profile sanding stbd wing/strake top and winglet
Over the last few days started profile sanding FILLed area, starting with the well cured wing root, 40g with the Festool, backed up with a 40g hand block for gentle/complicated work.Occurs to me along the way that when I add the wing root heat shields my beautiful cowling transisiton will be affected. Hmmmmm. Glance at the sheet of 0.020" 6061 in the corner. Maybe it is time!
