Brief Description: Epoxy WIPEs and started finish sanding
WIPE #5 and complete - Fuselage bottom and sides
Started finish sanding mail landing gear cover 240g. I start on the flat areas dry with the festool, then finish off trickey bits with a hand wet sand. Sometimes the Festool does a lovely job, sometimes it leaves a smeary residue, which the wet sanding deals with. The result is an amazing hard and flat matt finish that just feel gorgeous!
