Profile sanded all filled bits and they look lovely.
Only problem was the rudder. I have efficiently sanded off my lovely Kruger flap :( Prep sand the surrounds and hot glue on some plastic pipe for a form. Layup 3 x BID with a tapered overlap.
Decide there is a slight low spot and a ragged edge on the fuselage in front of the landing brake hinge, so glue on a form and add FILL.
Filled some more low spots, and the edges of the fuel blisters. FILLed the diffuser and blended into the NACA.
