Brief Description: Bolting up canopy hinge brackets
Finally found an approach that works. Set up a 5/8" forstner bit in the drill press, and clamped the canopy frame to the table. This stops the hole from wandering nicely and makes it much easier to achieve the required depth. A lot of time waiting for the bit to cool down, is spent in a rare shed cleanup.
Bolting up the brackets as I go.
Made up a bit more of a flox fillet around the brackets, and started potting the top nuts in flox.
