Brief Description: Finishing 101 - ailerons and windows
I kept detailed notes, but it is all a bit boring. Added goo to window frames, adjusted flanges, profiled edges and repeat. Note that the landing light window flange looks too wide also, so trimmed it to 1/2".
Discover that the fuselage windows are a smidge different from side to side. The aft edge of the window is 60mm forward of the strake leading edge on both sides. The forward edge is 63mm aft of the instrument panel on the port side, 57mm on the starboard. The starboard window is 5mm shorter than the port, The missing mm must be hiding in a slight lack of squareness somewhere... The bottom and top edges are within 1mm.
Made some more window templates, in a wierd profusion to match my feng shui on the corner profiles.
