Home of the Spodplane
Date:  8-18-2017
Number of Hours:  1.90
Manual Reference:  14-01
Brief Description:  Wing CS Spar jig
Re-trimmed D diagonal on R. Trimmed L 3mm under and hot-glued on a strip of 3mm ply. Remarked diagonal shelf lines - measurements all good, tips BOTH at 7.46". Cleaned up bottom of D and is sitting nicely.
Placed D back in it's nails and brackets and bondo'd into position.
Bondo'd A & E in position. Result is square and accurate. Will leave to cure before fitting remainder.
Cut out remainder of "one inch" sticks, using old 19x35mm jigs.
That looks better
That looks better
Bondo, bondo
Bondo, bondo
Its good! Its square! Its accurate! I'm tired!!!
