ER tank access panel for left wing planned. Due to previous location and installation of the Vans stall warning access, the standard ER tank access panel will not fit. Required access for the ER tank and pump is not possible from the stall warning access. Due to the lack of required access, I decided to remove the stall warning access and replace it with a nominally larger access panel that will allow the necessary access.
The new panel will overlay the stall warning panel and be large enough to encompass the tank access location.
Once this decision was made, the stall warning acces panel double was removed.
