Rivet hinge, spacers, and doubler to wingtip using p-squeezer.
Rivet hinge to door using p-squeezer.
Install door using hinge pin. Note: Need to get additional pin material.
Temporarily install camlocs. Retaining washer not used at this time to facilitate painting.
Close door and loc camlocs.
Verify fit of door, wingtip, opened and closed. Specifically check clearance between camloc receptacles and tank. Nominal minimum clearance of 1/8" achieved.
