Rivet connector mount to servo mount using p-squeezer.
Install servo in servo mount per plans.
I decided to use AN bolts and nyloc nuts to hold the connector flange to the servo mount flange and spacers due to the extended length of required rivets.
Install nylon braid over wire group and secure servo end using heat shrink tubing.
