Bobs Ten
Date:  2-16-2014
Number of Hours:  1.40
Manual Reference:  OP38-3
Brief Description:  Install Aileron Trim Servo
1530 - 1654
Dimple connector mount for flush rivets.
Debur, clean, and prime DB-9 connector mount.
Cleco connector mount to servo mount.
Rivet connector mount to servo mount using p-squeezer.
Install servo in servo mount per plans.
I decided to use AN bolts and nyloc nuts to hold the connector flange to the servo mount flange and spacers due to the extended length of required rivets.
Install nylon braid over wire group and secure servo end using heat shrink tubing.
Install DB-9 pins using pin crimper.
Install heat shrink on wire group connector end.
Install DB-9 connector in mount.
