Bobs Ten
RV-10
35-3 > 35-5.4
Rivet Rear Seat Pans, Complete Tunnel Covers
1342 - 1454 1624 - 1742
Rivet center and outside edges of rear seat pans using p-rivet puller and hand puller.
Rivet inside edges of seat pans using p-squeezer.
Install nut plates, as specified, using p-squeezer.
Final drill all applicable holes in tunnel covers using #19 drill.
Debur all holes and dimple as specified for #8 screw.
Cleco tunnel cover splice plate to tunnel cover.
Match drill holes using #40 drill.
Remove clecos.
Debur holes.
Dimple holes for flush rivets using DRDT-2.
Rivet specified nut plates to tunnel splice plate.
Rivet splice plate to tunnel cover using p-squeezer.
Inspect all sub-sections pertaining to QB/Standard kit to verify completion.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
