Bobs Ten
Date:  6-21-2013
Number of Hours:  0.60
Manual Reference:  36-2.1
Brief Description:  Remove Cabin Heat Flanges
1500 - 1536
In the QB fuselage kit, the DL-10 scat tube flanges had been riveted into postion in the forward tunnel with the VA-175 scat tee. This was problematic because the hard brake lines would not easily fit behind the flange/tee assembly while in place. I decided to remove the flanges and tee to allow clear access to the tunnel and firewall for fabrication of the hard brake lines.
The flanges and tee will be reinstalled once the brake lines are installed.
Drill out rivets in both DL-10 flanges.
Remove flanges and tee.
Debur holes in flanges.
