Bobs Ten
RV-10
35-2.1>5
Rivet Aft Floor Panels
1300 - 1430 1518 - 1724
In the QB kit, the floor panels were pre made and temporarily installed.
Removed aft floor panels.
Install 3/4" insulation.
Cleco floor panels in position, every other hole.
Match drill holes in forward spar bulkhead using #30 drill.
Debur holes.
Rivet panel to outboard footwell rib using 3x gun, 2x.
Rivet panel to inboard footwell rib using 3x gun, 2x.
Rivet panel to rear spar bulkhead using 3x gun.
Rivet panel to forward spar bulkhead using p-rivet puller.
Rivet panel to floor stiffeners using p-rivet puller.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
