Bobs Ten
RV-10
Install Airward.com Tunnel Access Panel
1424 - 1724
Remove 11 LP4-3 rivets along bottom flange of right floor pan.
Cleco pre made double to these holes. As stated in the airward instructions, holes did not line up.
Moved doubler 3/8" forward and match drilled tunnel flange holes to doubler, cleco as drilled.
Match drill all perimeter holes using 340 drill, cleco as drilled.
Match drill 4 corner holes with #12 drill.
Remove doubler.
Debur holes.
Cleco access panel to corner holes.
Mark edge of panel.
Remove panel.
Enlarge corner holes using unibit.
Cut side of tunnel using metal body saw.
Debur and smooth edges of tunnel hole using vixen files and s/b wheels. Removed enough material to fit access panel.
M-Countersink all #40 holes in doubler for plate nuts.
M-Countersink panel holes for #8 screw.
M-Countersink #40 holes in tunnel.
Debur and smooth all edges and holes.
Prime doubler and panel.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
