Next I wired up the "red cube" fuel flow sensor. Nothing difficult, just soldered the sensor wires to the EMS wiring loom wires. I did think about fitting a plug/socket, but figured this isn;t somethingt that'll need to be changed very often, if at all, so I may as well just solder the connection.
I also fitted a cushion clamp, just to relieve any stress on the wiring.
Out with the soldering iron, making the connection to the "red cube" fuel flow sensor
Red to red, black to black, yellow to white ... hope that's right
