Brief Description: Oil return hose from turbocharger
I started looking to where I might route the oil return hose from the oil pump to the tank. It's all a bit tight in this area but one thing I did notice is one Rotax installed hose from the water pump to the #3 cylinder head is kinked. I'll need to determine if this needs to be changed.
