Most of the parts I ordered for the backbone wiring have arrived, just 1 C/B & some wire to come. Today started by mounting the E-bus diode & heatsink using 4mm rivnuts & screws then I trimmed the VPX 16sqmm feed wire to length & installed its crimped lug, Two 18ga wires feed the diode from the VPX input post, I made & installed them. The fuse holders & fuses for the generator outputs arrived today, I've started thinking where I'll place them on the firewall.
