Norris's RV Construction
RV10
Started installing engine but removed it.
Mounted the Engine but removed it because the engine side mounts did not match with the Vans mounts. Talked to Lycoming and they are sending the correct mounts.
upper mount. Angles don't match.
Lower mount. Angles don't match.
RV10 Home
3556
10 Avionics
51
293
10 DeIce
10 Empennage
10 Engine
10 Finish Kit
10 Firewall Forward
82
446
10 Fuselage
180
977
10 Inspection
10 Interior
10 Miscellaneous
10 Paint
10 Rear Fuselage
10 Wings
95
527
De Ice
RV14a Home
