Tested the deice system and modified the deice display software. Made two changes. First I changed the location display to match the order and location of the actual fireing order. Second, my son (who wropte the program) explained the change I needed to make so that when the system is first turned on that the display will pick up the correctl first actuator to fire. This is required because the fireing system acts faster and fires the first actuator while the display is booting up.
