Terrences Web Site
Date:  2-15-2015
Number of Hours:  4.00
Manual Reference:  6-ZU-1pp14-15
Brief Description:  Drill nose rib anges for left spar NR#2, and NR#1
1. Drilled holes, 3/32”, 1/8”, #20 through angles to attach NR#2 to angles. See Fig.
2. drilled holes 3/32”, 1/8”, #20 through the wing root doubler to attach angles for NR#1 to spar. I used a piece of .040 behind the wing root doubler to protect the spar web from the drill when it penetrated the doubler. That worked well.
Holes drilled to attach NR#2 to angles
Holes drilled to attach angles for NR#1 to spar
Copyright © 2001-2018 Matronics. All Rights Reserved.
