Brief Description: move port side inlet hole on bottom cowling
Image # 1 below shows the port side upper cowl inlet hole moved farther outboard so that it is centered on the SCAT tubing that goes back to cool the alternator. The approach of using a long diagonal cut to enable that move seemed to work, so I am using that same approach to moving the port side inlet hole on the bottom cowling, as shown in Images 2 and 3 below. As I have been doing these hole moves, my entire focus has just been on keeping the moved fiberglass properly aligned with the other inlet holes on the front of the cowlings. The impacts on the top and bottom of the cowlings has not been pretty, but I will deal with that later.
