Brief Description: continuing work on cylinder baffling
Getting close to 'to done with the first piece of baffling for the cylinder heads. this one goes on the front part of the port side of the engine (pilot's left). on this position, and I hope also onthe rear part of the starboard side of the engine, the small extension piece seems to work okay rivetted directly to the baffle material itself, since it wraps around the cylinder head far enough to accomodate that before it runs into the push rod tube. Looking forward, I can already see that this is not going to work on the other two corners. (port side rear and starboard side forward). That is because in those locations, the push rod tubes are right at the turn from the vertical part of the baffle to the horizontal part of the baffle, so I am going to have to figure out a different approach there. More on this tomorrow.
