Construction Of the Europa XS
Europa XS
Door recesses joined
The top of the fuselage, above the seating area has to have the door recesses joined in the middle. This is to spread any over stressing evenly around the fuselage.
The blue foam is shaped and covered with 3 ply’s of BID
Aft door recesses joined
Front door recesses joined
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
