Construction Of the Europa XS
Europa XS
Removable Panel
Although not in the manuals as it should be. I decided to take this opportunity to close off the tunnel just behind the landing gear frame.
I cut out and cover a piece of 3mm ply with a piece of bid on either side.
To make the flange, I held it in place with release tape and laid the bid around the edges. After cure all fixed in place with anchor nuts.
Ready for layup
The LayUp
Compleat
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
